Megane R26 aircon delete.
R26230F1
Hi guys,
Got myself an R26 again and the aircon is dead. Switch it on and off and no revs dipping and no cold air.
It’s used as a mild track day car and considering getting the aircon removed for the pms pulley. Question: is it worth it? Bhp gains? Quicker revs?
When the A/C is not on, the pump flywheel is just spinning, so it's not exactly sapping energy.
My R26's AC is a little bit patchy at best. New Condensor, pipes and seals fitted and still the gas seems to escape every couple of years..
Just a case of re-gas with some UV dye and see if you can find the leak??
After a struggle, managed to keep the aircon, on my 250engine Meglio. Its very tight, and had to move rad forward around 20mm, but in the warmer weather, and on track, for me, its well worth it.I do not care if it takes 10hp from the car, with my bad driving, you wouldn't notice. After 6 laps, on a hot day, I have got out the car shivering with the cold!.( Idiot!.)
That was a waste of time. Halfords guy couldn’t find the low charge point. Then read some terms that they aren’t covered to look under the car.
Shame Really.
Noticed my power flex insert has split too
