Wanted R21 sunroof
ferswin
Anyone have a non leaky/rusty r21 sunroof off a ph2 if there is any difference?
Also need r21 front windscreen seal/surround, are these still available new?
Cheers
Cheers
Phase 1 and 2 are the same until you get to the later tilt and slide ones, they're different but can be retrofitted. @roddy21t rebuilt his 21 sunroof with a R19 one, they're very similar.
I've got my old one in the garage, it's complete and the motor works but it did let water in and the drain tubes would need repairing. Can send pics if you want, i'm changing to a non-sunroof skin.
Front screen surrounds, yes, these are very good.
Thanks that's great, will order that kit! Ooo where to get non sunroof skin?
Do have any other tasty bits to tempt a swap, other than sunroof of course haha
Well there's my existing Team Dynamics Pro Race 1.2's in Bronze
In terms of goodies, I'm not sure.
I've a fair bit std stuff, 2x rear bumper, 2 x bonnet (1 is louvre punched)
I've got a pair of headlamps and indicators but I'd need cash plus Azevs and likely an under 50yr old female to part with them haha
Well, I did a 750 mile round trip to France for mine off a breaker 2.0na, took the whole roof and pillars then painstakingly unpicked it from the inside out.
Thats after watching out for several years for a new skin, never did find one.
More info on my build thread.
Whereas I plated the hole up and had it filled etc
Dave's work will look better than mine but mine was far easier
Far far easier. Yours looks great on the outside, but I worried about longevity (cracking etc) especially with a cage in it, the stresses of 400hp (I hope) and the abuse it will get on track, over kerbs, and so on. I suppose how it looks inside doesn't matter too much? I did get the full roof lining with mine though, doubt i'll be able to use it with a cage so it might come your way mate.
Omg Dave, that looks like an insane amount of work, yep think I will be going down the plug and fill if I want to lose the sunshine window! Great to see your build thread and commitment to the project!
Want to swap for just the new pair of indicators? :)
Cheers
I separated the sunroof glass from the metal mounting plate, cleaned it up & re tiger sealed it. It worked a treat.
