Poxy Air Con
AcidV6
Driving Along nice today & ................ Nothing
Air con/fans packed up- right in 26C degree heat-
Sod it!!
Gonna be without the vee all weekend - S'gotta go into Masters of Beckenham....
S
Have you checked the fuses / relays to make sure one hasn't jumped out of its socket?
James":2uggs1m3 said:
^^^ Good thinking. Found one of my relays on the floor once.
Im not very good with things like this- Am I looking for a coventional fuse box to check fuses- or is it a little more complicated than that-
Where am I supposed to be looking???
S
John V6":12ktb9ir said:
If the fan does not work A.C. will not come on
Had a quick look at the fuses- All looks in order-
However in the maintenaince book & on the fuse cover there isnt actually a symbol for Cooling fan- ??
There is one for Engine Fan - but nothing for A/C or interior fan ???
Strange..
S
I meant the heater fan not the fans at the front of the radiator.
Just looked in handbook and the fuse is not called up, I will look in the workshop manual and try and find out more.
Could be a relay sticking or U.S.
Does the heater fan come on when you set to full speed ?
It would seem the following fuses are associated with the A.C.
F3 = 15A
F6 = 10A
F34 = 20A
If the inside fan does not work fan may be U.S. or the speed controlloer U.S.
A Renault Dealer can soon connect his Diagnostic Computer and carry out the checks, all clearly stated in the manual and locate the fault fairly quickly.
S
I think there are more fuses / relays in the front boot (this was certainly the case in the 182), covered by the black plastic box with the gold screw pin holding it down - make sure all the big plastic 'blocks' are all in place.
I had my compressor replaced a couple of months ago under warranty thank the gods and now she blasts icy cool air on demand, essential in this heat. All the symptoms I had was a slight squeal from the belt now and again for a second, a shredded belt can cause major havock in there :wink:
