Had a quick look at the fuses- All looks in order-
However in the maintenaince book & on the fuse cover there isnt actually a symbol for Cooling fan- ??
There is one for Engine Fan - but nothing for A/C or interior fan ???
I meant the heater fan not the fans at the front of the radiator.
Just looked in handbook and the fuse is not called up, I will look in the workshop manual and try and find out more.
Could be a relay sticking or U.S.
Does the heater fan come on when you set to full speed ?
It would seem the following fuses are associated with the A.C.
F3 = 15A
F6 = 10A
F34 = 20A
If the inside fan does not work fan may be U.S. or the speed controlloer U.S.
A Renault Dealer can soon connect his Diagnostic Computer and carry out the checks, all clearly stated in the manual and locate the fault fairly quickly.
I think there are more fuses / relays in the front boot (this was certainly the case in the 182), covered by the black plastic box with the gold screw pin holding it down - make sure all the big plastic 'blocks' are all in place.
I had my compressor replaced a couple of months ago under warranty thank the gods and now she blasts icy cool air on demand, essential in this heat. All the symptoms I had was a slight squeal from the belt now and again for a second, a shredded belt can cause major havock in there :wink:
