PC Based XR25 USB Cables
Am new to forum today having issues with my williams atm and am in dedperate need for one of these leads cant find thrm anywhere else on internet. Have cash waiting are any more available at all please??
They're only available in one other place that i know of and are almost 3 times the price of ours.
Theres 2 left from this lot (available immediately)
order placed just now, do you have the leads from china for imediate dispatch or are you still awaiting delivery?? just so i know timescale wise for my delivery.
Many thanks luke
I make the leads myself and i have everything here to assemble yours so it will go in the post either tomorrow or the next day.
Question about the kit
Hello,
Does the DIY kit include a schematic on how to connect the PCB to the USB cable?
Which connections need to be made?
The connector in the car has 3 wires, i think?
A standard USB connector will work?
Cheers,
Marcel
There are two wires that need to be connected to the diagnostic port or ECU.
The DIY kit includes a 6-pin header to connect to a standard FTDI TTL cable
OK, great.
The kit is still available, or is it also limited?
Does the software have other options, for example fault reading like
the original XR25?
As far as I know the software fully emulates the original XR25.
It's my understanding that these ECU's don't store fault codes but rather the XR25 detects faults based on the output from the ECU so it should work.
Kits aren't limited.
I also have some FTDI cables if you don't have one
OK, great.
I think you are right, you can read errors with the XR25, but
they are not stored anywhere.
How much does the cable cost?
That way i can pay the total with paypal.
Many thanks!
Now i'm slightly confused...
To make the cable from the car to the laptop,
i need the DIY kit (12 pounds), only i need to have a USB cable to connect to the PCB.
Or, i can buy the complete cable for the 35 pounds and i do not need
anything else, right?
For £35 you get a complete cable, it is all you need.
If you buy a kit (£12) and FTDI cable (£16) you will have the same functionality as the complete cable but you will need to assemble it and solder wires to the car.
Just to update my order. Stunningly happy, confirmed a few thoughts I had with my engine and getting huge amounts of useful data to work out what to keep on top of!
Hi,
I had planned on keeping the last one for myself but i ordered some more bits for new cables today so yes, i have one more complete cable available if you want it
Chet
