See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: An error occurred creating the form. See Exception.InnerException for details. The error is: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)) ---> System.Runtime.InteropServices.COMException (0x80040154): Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
at System.Windows.Forms.AxHost.CreateWithoutLicense(Guid clsid)
at System.Windows.Forms.AxHost.CreateWithLicense(String license, Guid clsid)
at System.Windows.Forms.AxHost.CreateInstanceCore(Guid clsid)
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.AxHost.EndInit()
at XR25_PC1_183.Form5.InitializeComponent()
at XR25_PC1_183.Form5..ctor()
--- End of inner exception stack trace ---
at XR25_PC1_183.My.MyProject.MyForms.Create__Instance__[T](T Instance)
at XR25_PC1_183.My.MyProject.MyForms.get_Form5()
at XR25_PC1_183.Form2.CheckBox6_CheckedChanged(Object sender, EventArgs e)
at System.Windows.Forms.CheckBox.OnCheckedChanged(EventArgs e)
at System.Windows.Forms.CheckBox.set_CheckState(CheckState value)
at System.Windows.Forms.CheckBox.OnClick(EventArgs e)
at System.Windows.Forms.CheckBox.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3634 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
XR25_PC1_183
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Apps/2.0/VPCYADCA.L1Q/C8TXLPCO.5AT/xr25..tion_e867d6479548b958_0001.0000_35955b5d9024a055/XR25_PC1_183.exe
Win32 Version: 2.0.50727.3637 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 2.0.50727.3639 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Microsoft.VisualBasic.PowerPacks.Vs
Assembly Version: 9.0.0.0
Win32 Version: 9.0.30729.1
CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Apps/2.0/VPCYADCA.L1Q/C8TXLPCO.5AT/xr25..tion_e867d6479548b958_0001.0000_35955b5d9024a055/Microsoft.VisualBasic.PowerPacks.Vs.DLL
AxInterop.MSChart20Lib
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Apps/2.0/VPCYADCA.L1Q/C8TXLPCO.5AT/xr25..tion_e867d6479548b958_0001.0000_35955b5d9024a055/AxInterop.MSChart20Lib.DLL
MSDATASRC
Assembly Version: 7.0.3300.0
Win32 Version: 7.00.9466
CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Apps/2.0/VPCYADCA.L1Q/C8TXLPCO.5AT/xr25..tion_e867d6479548b958_0001.0000_35955b5d9024a055/MSDATASRC.DLL
CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Apps/2.0/VPCYADCA.L1Q/C8TXLPCO.5AT/xr25..tion_e867d6479548b958_0001.0000_35955b5d9024a055/Interop.MSChart20Lib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
