The Clio absolutely smashed it on track today, for the most part it didn't miss a beat (well a few minors but) Its been a long while since I've done a proper track day, and I was a little dubious as to how I would like it in a full road car and without a manual box, but tbh the gearbox made it for me. Supersmooth delivery of power and the ability to shift through corners without unsettling the car or taking time to actually actuate a shift made it quicker I'm sure. It defo could do with longer paddles in some corners though.
Where to start...The temperature outside was passing 23 degrees at points of the day, id had concerns about intake and running temps previously so added the ducting and panelling. That with the number plate out of the way kept intake temps around 35 to 37 degrees, which is awesome in fairness. The highest I saw the water was 107c, again nowt to worry about. Considering I was flat out a lot today deep into 5th gear at times it all worked very well. I had no dips in power or pull back from temps at all which I was expecting. I also had no issues with the clutch, the car was delivering all the boost it could all of the time
The tyres held up great and brakes were awesome too, if i was going to get serious about track time or just a little more into I may look at brembo 4 pots, but the brembo max pads and stock disks worked very well.
I put in plenty of laps through the day, getting quicker and quicker as i built up confidence, pushing plenty of "track" machinery out of the way at times. Managed to rinse a tank and half of fuel before calling it quits. The reason I actually did stop was due to fuel issues. Now this isn't a major and it'd probably only ever happen at Mallory but Gerrards, when starting to dip under half a tank and definitely at a quarter of a tank causes fuel starvation. The quicker you go and the more speed you carry the worse it gets. The car will protect itself when it senses the fuel pressure drop, it'll pull back briefly and then auto shift up a gear or 2 (very annoying when it happens) I don't think its really something I need to address as back in the day i had the same in the itb and sc 172s, and it only ever did it a the same track on the same corner....
The only other thing that happened was a silicone blanking plug burst on the tb adapter. Luckily, the only part I thought may let go was that, so I had a spare bit of pipe with a blanking plug in ready to go.
Loads of the mk1 valver guys were in attendance, in their absolutely rapid cars, proper little Renault take over on track today. MK1's 2's 3s and my 4 in attendance with a meg 3 rs out there too
All in all a great day and I'm very much looking forward to CSF. The only thing I want to do before then is get the back end aligned and equal along with some PMT mods to the shock towers so I can dial in a little camber. Should hopefully help me carry a little more speed through the corners without it starting to squirm early.
