We seem to have taken 3 steps forward, but immediately a couple of steps back.
So I picked the ECU up today. Emulator fitted, ECU tested at JR. Powering up and accepting the immo code.
Run a few errands, before getting home. Eagerly popped the ECU onto the engine loom of the Megane, and before cranking it over, decided to plug into Delphi and just seen what was happening.
Good start! It allowed me to clear down the 6 million logged fault codes from previous ownership, and me powering it up last month without any components plugged into it, like throttle pedal etc.
So fault codes all cleared.
Jumped onto component testing, this also was unable to work before the emulator was fitted. But went into fuel pump testing, hit the button, and it primed the fuel pump for a good 20 seconds. Long enough for me to set the FPR at 3.5 bar for a safe engine start up.
After temp fitting the IC onto the original pipe work so I had a full intake circuit, I turned the key.
Cranked it over on the key, FPR gauge did a little dance as it was firing the pump up, but no engine starty.
So first things first, pulled the ignition coils out, pulled the plugs out, chucked plugs in the end of the coils, and cranked it over on the key again, just to see if it was even trying to go.
No sparks.
Ran a quick test on the multi meter from ECU pins to coils 1 and 4, buzzed out fine.
Power lines to coils 2 and 3, take their feed from the fuel pump power. So when fuel pump is on, coils are charged, so to speak.
Fuel pump off, 0v (Ground) at coils 2 and 3.
Fuel pump manually primed on the relay with power probe.
12v at coils 2 and 3.
So all wiring is good and working.
Refitted plugs, coils, and tried again. still nothing.
So chucked the Delphi back on, to do a quick read / get some live data.
And it's behaving like it was before the emulator was fitted.
Wont let me erase any fault codes again, and it also wont let me run component testing.
So a bit frustrating.
So I'm aware that the car can not send a key signal, otherwise the ECU receiving 2 different key signals (1 from actual key, and 1 from emulator) will give a code clash, and it wont work.
AFAIK, the original Megane IMMO had it's own designated line into the old 1.6 ECU. But to be sure, I disconnected the K-line from the car loom to the Laguna ECU, just incase it was sending a key signal through the old OBD. My theory behind this, is the ONLY wiring from the body of the car, to the Laguna ECU (Apart from obvious 12v feed, earth, and throttle pedal), is the K line to the OBD socket. And I just tapped into the original K-line wire at the original engine loom plug.
However, it made no difference. And still no spark.
I noticed the fuel pump did not do an initial prime on ignition power up. So I'm not entirely sure what's happened. I'm a little out of my depth with it.
I've turned it in for the night. The Megane battery is on charge, the ECU is off and in the kitchen. I'll have another look at it over the weekend, But I've got a feeling that the S3000 ECU, with an emulator fitted, maybe isn't an option.
Other than the logical advice from a couple of tuners, and somebody who is on the Renault scene that it 'should work', I've never actually spoken to somebody who HAS done it. So as far as it's looking, maybe it's just not a working method.
Fitting all the shite out of the Laguna, is not an option.
So if this cant be overcome with the S3000 ECU, then I think my only options are to either run a Ph1 172 ECU and throttle body on an adapter plate, then run stand alone turbo management.
Or, stand alone engine management. But I dont really fancy the price tag that comes with that.
Delphi not wanting to clear codes down.
And one thing that concerns me a bit.
Does this mean, that the immobilizer is active, and NOT letting the engine start.
Or does it mean that the key / code has been accepted. I.E, engine start is activated.
