Megane Megane Magnetic Maxi
Hi ynot.
I took a very different approach to my Maxi megane suspension. I modified all the std parts from F7R to match what I wanted. As I had the Proper Maxi arches the wheel was not central so I had to extend the lower wishbones forwards as well as outwards. As for the rear, I cut and stretched the std axle. I have pictures available if you wish to see it.
Hi ynot.
Yes pictures would be nice :)
So as this is not a real maxi kit i have desided that i will start with The second car the 1,6 car that i started with so i can get bigger wheelarches
Skickat från min SM-G930F via Tapatalk
