Red21
8200725672 (nearside) and 8200725673 (offside).
8200725659 (n/s) and 8200725660 (o/s).
One's listed as the 225, the other R26/r, but I thought exactly the same spec part was fitted across the mk2 RS range...unless one set of part numbers have simply just been superseded?
Unfortunately all those part numbers are still "No stock"
The 8200725672 & 673 are 225 (CM0M) versions
The 8200725660 & 659 are R26(R) versions, they have changed from 8200646919 (RH) and 8200646917 (LH) and these old part numbers are NLA (no longer available)
I have left it with one of the parts guy who will email NPDc to seem if there is any news on a supply date.
If the ball joint on the arm is the only part that has failed there may be an alternative method by replacing the lower ball joint only with one from a normal Megane II (CM0C) as per picture.
There is a specific repair method for the ball joint replacement & I will have to find the appropriate repair documentation for this.
