Hard to tell what's going on, even with pics, but from my experience with bonding stutt etc on grp cars, I'd be looking at ditching bolt that's in and putting another on through that's tack welded onto some sort of plate, basically if be aiming to get a decent surface area to get the adhesive on, if that makes sense?
Bolt through a hole in a plate and welded won't shift on plate, then if plate is made to fit into what looks like a right angled recess, some two pack adhesive on a good few inches of area won't budge either?......I ain't there so I'm only making assumptions.
Correct - 17 is metal.I get you now, the captive nut is the problem as it's not captive anymore, how was it fixed to 17 to start with ? Assuming 17 is metal?
I was thinking it was a captive bolt bonded in.
Fixings on GRP cars are always fun, GTA's use lots of rivnuts into GRP.......add a few years and some corrosion, they spin and you can't get off what you need to get off to access what's wrong!
Due to the location , I am not sure it can be rivnut.I'd be tempted to rivnut that I think.
I didnt need to. I took it out when it was tacky.You should have greased the end of the bolt so it wouldnt stick![]()
TBH I am unsure. More is the only answer I can give really. I am for the first time not mega concerned about the increase more bothered about efficiency really. I am convinced the manifold and OE car are restrictive.What increases are expected @andybond Looks nice![]()
