nudger2802
JB3 or JB1 gearbox advice?
Hi Folks!
I am after a bit of advice please!
I have got a 1994 Renault 21 1.9 Diesel Savanna (Dont Laugh!
) and I am pretty sure my diff decided to give up the ghost yesterday.
I was driving along as normal and suddenly a slight dull occasional knocking started and the steering occasionally pulled to the left getting worse as I carried on. I was on country lanes and couldnt really stop safely so carried on for about 5 miles untill I could find somewhere safe and under a street light.
When I stopped I checked & topped up the gearbox oil (luckily I had a couple of litres in the boot) and it took about 1.5 litres (its been leaking) and when it started to run out the filler plug i got a mix of fresh oil and mayonaise(n). I reversed out of where I had parked and got real bad clunking on taking up drive.
As I drove forward the clunking wasnt quite so bad but still really noticeable on take up of drive and cornering and seemed to get a bit worse as I drove the 10 miles home, when cruising at speed there is no clunks and the gearbox is really smooth with no whine or any unusual noise, only clunking on cornering or under load.
I thought it might be a drive shaft from the symptoms but on jacking the car up today found that if I rotate either front wheel it goes so far then locks up against something before turning any further suggesting the problem is the diff.
Has anyone else had a similar problem to this and found it to be something really stupid or am I right in thinking I am in the market for a new gearbox?
Also does anyone know if all JB3 gearboxes are interchangeable apart from the actual ratios?
My gearbox code is JB1S34 and its mated to a F8Q710 1.9 Diesel.
Am I right in thinking this is a JB3 box?
At 196750 miles I dont think its done bad if the gearbox has finally given up the ghost lol:lol:
Thanks,
Nige
Hi Folks!
Thanks,
Nige
