Hi there as i have posted before i have put an F7P in my volvo 340 and am over the moon with the way these engines perform.
Quick question, when i first start the car from cold and the 5th injector is working the car idles perfect, but as soon as this stops it hunts ever so slightly.
Then if you take the car for a blast it revs at around 2k then when you come back to standstill. Took the car to a renault dealer and the bloke seemed helpful enough. He suggested changing the air temp sensor first?
I thought this sounded like lambda, although teh lambda is only a month old, althouth not a genuine. The lambda did look different to the OE one!!
Any help much appreciated!!
Cheers Adam
Cheers Adam
