how to PAS conversion?
G
Guest
How hard would it be and what parts would i need to convert from a non PAS to as PAS? surely i can find some used parts in goodshape but i expect it would cost abit..
Is this for a valver?
You'll need the correct PAS/Alternator bracket for a start, cheap to get hold of. You'll also need a PAS pump & pulley, and piping leading from the rack to the reservior, and back round to the pump (three pipes in total IIRC).
You'll also need a PAS rack and steering column.
You'll need a slightly longer AUX belt as well.
Think that should be all.
