Gear lifter
Jonny
Hey i need a gear lifter for my vee, its the plastic part below the gear knob which you lift to put the car into reverse gear, just wondering will this e the same lifter as in standard clios? is it any easy thing to fix? someone has removed it from mine and fitted an aftermarket gear stick.
I've looked a a few different Renaults and can't find one with the same part number as the Vee uses.
7701059964
£36.16
Yea got it sorted cheers, when i got my vee home i noticed it actually had the lifter, It was moggsie who said it had no lifter, but it had a lifter and someone had glued the gear knob on and the glue had ran down the egar stick and stuck the gear lifter up so was just a matter of taking it off and cleaning the glue off, and voila new gear lifter haha. But would you have the spring for it mate as it has not spring on it to push it back down once i lift it up? cheers
Sorry pal, someone nicked the gear knob before I got there!!!!!!! No idea what happened to the spring.
Just got the gaiter and lifter with centre console ;)
BUT just pulled my knob off ( OMG that sounds wrong!!!!! ) and measured the spring up for you;
35mm long
23mm outside diameter
1.3mm guage wire
Hope it's some help :approve:
