Hi Guys,
I've recently finished my Meglio project but have one (hopefully last) issue to solve, when the car is up to temp and left idling the revs drop to almost stalling before picking back up again. So far I've replaced both lambda sensors with new genuine, checked for vac/boost leaks and swapped out the MAP sensor for a known working one.
I've noticed that when this is happening the STFT drops to -100% briefly before recovering. This also happens when cruising at a steady throttle input and can be felt as a slight hesitation before continuing as normal.
I think my next move might be a fresh set of injectors (its currently on 630cc injectors and has been mapped by Chris at EFI)
Any suggestions?
Cheers
Any suggestions?
Cheers
