Front Top Mount Which Part No.?
shinji
If I were to replace the front standard top mounts with new ones, do I need to replace the lot or just Item 4 in the pic?
Item 4: 60 00 073 600
Also, which P/N is needed for Ph 1 (CB1A) for Item 3? It has 2 P/Ns
60 01 025 925; and
60 01 025 850
I know there is a top mount kit from RPD but it seems to be a waste as I don't need Item 1 and 2.
I'm going down the coilover route with standard top mounts at the moment cos most of the solid top mounts I've seen so far requires drilling extra holes in the suspension turret.
[smilie=thanks.gif]
item 4
MOUNTING UPPER C2
60 00 073 600
£30.37 GBP
item 3
STOP-ROTARY
82 00 651 172 replaced part no. 60 01 025 850
£10.12 GBP
Been trying to order Item 5 and 6 from the pic in the 1st post but got quoted with these part numbers instead…..
82 00 867 250
77 03 032 174
Can someone be ever so kindly and check if these are correct for a phase 1 vee? and perhaps a reference price too?
[smilie=thanks.gif] in advance!
Silly me, I just found :ihatpcs:
Item 6: 77 03 032 174 Nut
from one of James's old post LINK
But I am still stuck on Item 5. In the 2010 post it has a P/N 82 00 666 449 but I got quoted 82 00 867 250. Has this P/N been replaced?
