Front bumper removal rough guide
Matt
Hope this helps!!
Refitted bumper today and took some photos to be added to the guide (hope its helpful Ben/James)
1. Remove the 2 small black clips from the plastic top panel to release it. Pushing up from the bottom is the easiest way with a small screw driver. Unclip the alarm push switch too.
2. Unscrew the 2 bolts underneath the Car on the undertray.
There are 2 bolts to remove in the centre just above the number plate.
3. Remove wheel on each side of car and unscrew the arch Liner to gain access to the nuts and bolts behind
4. There are 4 bolts in total behind the bumper to release it as the pictures below show:
2 bolts in the corner can be unscrewed with a small spanner and a stretch of the arm
The other 2 are nearer the edge and are much easier. Loosen but don't unbolt fully until you are going to remove the bumper.
Disconnect washer jets and fog lights
5. Voila - bumper should come loose. Have something soft to drop it down on to and take it easy when removing as you dont want to scratch you wings or anything.
6. Repeat reverse for refitting.
Nice guide Matt...I am a seasoned pro at taking off the bumper now, can do it in under 20mins!!! (then again i've done it a few times and i have little girly hands!!)
Thanks Matt, nice to see. I am removing mine in a week or so (just to clean etc) an will check this again.
