gbuk
when i got the blue ph1 cab there was no feel/pressure on the brake pedal,and the abs warning light was on,i checked the fuse today,it was fine,i cleaned the fuse blades and put it back,there was a groaning noise,the pedal pressured back up and the warning light went out,
with the car stationary,if you imitate gental braking it seems fine,if you dab hard on the pedal keeps pressure, the warning light comes on,then the groaning type noise comes on,the pedal pressures up and you can feel it push the pedal back up,
any ideas?
any ideas?
