Dr_S
Hi, the williams head have bigger valves, won't this be an issue ?!
Nope
Nope
short answer is yes 2l bottom end williams ecu job done.
Theres longer answers but they don't really matter.
yeh but it wont fit it fails on somthing
Cheers for that, you must be able to get a 4 branch for the 19 16v somewhere then?
well yes but you have to ethier wait a loooong time for a 2nd hand one to pop up or pay money for a new one. not sure where from
click it![]()
What would be the best combination to build a 2L 16V using a distributor? Would putting a F7P head and a williams ECU actually give you the same results as a F7R or would you be better off just getting the head and block from a willliams clio and putting the whole lot in?
cheers
hi. every one
finally I end installing f7r 2.0 (714) in my 19
I start working from 2 weeks ago this are some pictures of project
when the projct ended I will post all
thanks you all
http://imageshack.us/f/204/0132q.jpg/
http://imageshack.us/f/254/0111u.jpg/
http://imageshack.us/f/846/0113o.jpg/
