rentalkang
Hey guys, am new to this forum, and especially car repair in general.
I've always had a vested interest in cars and I reckon "theoretically" I've got sufficient knowledge to do things, but being based in Singapore we don't have the space and/or means to.
For example, most of us common folk here live in flatted, common, government-subsidised housing apartments, and as such we don't have our personal garages or driveways to work on.
It's also illegal to carry out car repair, or even wash your car in a lot here in Singapore.
I'm trying my best to skirt these laws as I have a private drive at my place of work where I'm allowed to carry out work and repairs on the weekends and it's completely out of sight from any members of the public.
First and foremost, I apologise for the incoming wall of text because I've searched long and hard for a support community for Renault, and it is definitely not easy to come by.
It's not even a popular brand in most countries, and sure as hell isn't popular here in Singapore either.
Compounding the problem is the fact that there isn't even proper support documentation (in the form of videos, or manuals or tips that people share online) for the X61 Kangoo II.
If not for this forum, specifically @Brigsy 's thread about his compact Kangoo, I would not have known that the Kangoo II shares so many things in common with some older model Renaults.
We do not have Autodoc here, so I have been using Fitinpart instead to check for replacement bits for my vehicle - just that it's a right pain in the arse because when you look up the cross-compatibility of the parts you need, the results all point back to just the Kangoo.
Now, about the vehicle.
It's a 2016 Kangoo 2 Phase 2 in Maxi form, K9K608 90hp Euro 5 dCi, JR5 manual.
Engine swaps and most mods in Singapore are also illegal and punishable by confiscation and destruction of the vehicle so I'll not be touching those.
I also have limited resources (car parts here are expensive, this is not my own vehicle - it's a company vehicle, and Kangoos are rare) so I will have to be very strict with budgeting with regards to any mods.
So far all I've done are really fairly basic things that do not even begin to skim the surface of what this forum has to offer:
- Upgraded audio system; reusing the original head unit with Bluetooth functionality, I have added a Hertz EP4 amplifier hooked up to two spare 20A circuits on the interior fusebox as well as a physical switch to prevent battery drain. Front speakers replaced with Focal Flax Evo PS165FE and two 10" BMB Karaoke speakers in the rear of the van acting as cabineted subs.
- Better interior lighting; the sad single W5W front dome light has been replaced with a 3-bulb, individually selectable dome light that is right out the RNA parts bin. This is a part from the Nissan Qashqai/NV200 van.
- K&N drop-in panel filter; because I like turbo noises.
I also do all my oil changes every 10,000km but that's about the extent of my knowledge and experience. More complicated stuff such as the 60,000km timing belt interval, or brakes, has been settled by the dealership. Luckily, the company has paid for those because they are deemed strongly necessary repairs.
What I'd like to do:
- Chase an annoying knocking/dull thudding noise that comes from underfloor. I have started with checking if the ARB bushings are shot - which they are not. I had them replaced anyway. This was a pain in the ass and no one told me that the subframe was going to swing out and hit me in the face. All I had for reference with regards to ARB bushing replacement procedure is a video from Youtube that's in Russian - if I recall correctly the guy's David Peknuy and he seems to have a wealth of information with regards to modern Renaults but I understand none of it because it's in Russian. I have also found that my outer tie rod ends are beginning to exhibit some play but it's not a massive amount and definitely is not causing the knocking I hear when I hit certain bumps. Again, @Brigsy 's thread saved me because I realise that it could be the two large bushings at the rear end of the subframe that are causing this.
Now, I could buy the bushings (company pays for the parts because it's cheap) but I'll be doing it with my arse on the floor accompanied by a 2 ton jack and a pair of jack stands. Sending it in to a shop is out of the question because the company won't pay exorbitant work fees and I'm not paying them either because I don't own this vehicle. It's not titled to me. I am lost as to how I'm supposed to press out the old bushing and press in the new ones.
- Changing the outer tie rod ends without having to perform an alignment - again, this is not up to me. Alignments cost money and the company doesn't care if the vehicle is aligned or not as long as it drives and stops, and passes annual inspections. I for one, find it very annoying to drive a vehicle that's out of alignment so I need to know if there's a way to do this without having to realign. Fortunately the procedure of changing the rod ends has been documented on Autodoc and I think I'm confident to carry it out.
- Clutch master cylinder - I have a clutch pedal that occasionally sticks halfway down and leaves me with a biting point 1mm off the floor. It also leaks yellowish/brown fluid out onto my footwell which I strongly suspect is the clutch master seals at fault. However, the reservoir (which I think it shares with brakes?) retains its fluid level flawlessly. How much of a pain in the ass is it to change out this master cylinder on a right-hand drive Kangoo?
- Lowering of the vehicle - This is more of a "want" than a need; I think it'd look stunning if I were to lower it slightly but again I cannot cross reference any other Renault based OEM parts, and even third party manufacturers like Bilstein only provide B4 replacements which are OE grade and not what I'm looking for. Again with @Brigsy 's thread I have found that I can use other springs and coilovers on the Kangoo but I might be a bit over my head with this one.
- Increasing boost via wastegate - This is also a want. There is nothing wrong mechanically with the engine and it has done 190,000km with no issues. However a little more speed is nice and seeing as I can't shell out for maps, tunes, piggybacks and whatnot, is it safe to adjust the wastegate nuts to give me 1-2 more pounds at best?
- Better brakes - I'm due for a pad and disc change soon, so before I order the Kangoo-only set of brakes, are there any fancier options out there that look stock both on paper and in real life? We use a parts stockist for company vehicles, so as long as it says RENAULT XXXXXXXXXXX on the bill the company would comp it. Additionally, I'm still on 15 inch steelies all round - would like to upgrade to cheap 17's one day when I have some money to toss around but right now is there anything I could use, from another Renault, that's a boost performance wise? Any small 4 piston setups for the front that require minimum conversion? I'm happy to leave the rears alone but if anyone's got ideas with 2 piston setups I'd like to hear.
Anyways, thanks for hearing me out and if anyone needs pictures I'll be happy to provide.
May take a little time though, as I usually only have the weekends to work on the car.
