i assume misfire codes again? 30 seconds isn't long for it to count up enough misfires to flag the fault, you shoudl be able to detect a miss like that easily.
just watched some of it back it gives me 2 lambda sensors oxygen sensor voltage bank 1 sensor 1 and oxy sensor bank 1 sensor 2 i take it that mean one before cat and one after as the one before voltage is jumping all over the place and the second is just dead with only 0.01 voltage change at a time should this be jumping about abit more ?
rigth just to add to that chris ive just live streamed my old mans 2007 ford focus cmax and after about 25 secs the second lambda start picking up data and basically follows the line of the first sensor so i guess either my cat or the sensor in nakered
secondly the second lambda should not switch, it should remain constant level output, with some slight variance and it will show rich when flooring it and lean when backing off but it will not switch.
The first lambda should be switching hi and lo at LEAST once a second. More is better, less is not.
I'm not sure what you mean by line, is this a graphical representation of the lambda output? if so whats the refresh rate of it?
Also if the old boys cmax was a cold start (less than 50 deg coolant temp) then it will be in open loop and the cat will be cold so the 2 sensors will mirror each other pretty closely until the cats up to temp. Which should then show a constant output on the secondary lambda and the usual switching on the primary
rigth cmax was from a cold start and did exactly as you said and yes sorry by line i meant graph but on my laguna from a cold start the secondary sensor just stayed dead no movement what so ever ? could it be duff
the cat is a ridulously small one basically tucked up under the turbo as the down pipe does a 90deg bend quite hard to give it a rattle
tail pipe feel as in hot ,condense ?
also the voltage for the first new sensor 0.125v to 0.735v
and secondary 0.480v to 0.490v
The light is saying an emission issue (all vehicles are programmed for emission compliance NOTHING ELSE) so the limited operation strategy will make the car safe to drive and retain emission compliance.
Basically its doubtful its the cat, unless its clogged slightly, what coils do you have on it? what plugs?
The coils will more than likely be your problem then.
cheapo ones cause more problems than they solve.
Only fit Beru ones. The rest cause these types of issues. if someone brings me a car and its cheap coils I decline the work and yes I have lost customers this way but they don't listen to reason.
I would fit new coils, or fond someone with a similar car and borrow theirs.
ours had cheapo ones on it and they were less than 6 months old. Crap.
i had experienced these issues with pugs and citroens with their big coil packs but only with our laguna and since then a few meganes that you really need the oe gear on them which is the beru units which are modified, the siemens give hassle as well but I think they have also been updated.
