yeah i read your thread very good ive dont the tb ect was quite dirty and had the black cover off and taken the magnet off ect not done the pedal so do i need to do a live data stream record it then see the results
some cars got a new wiring plug and short section of loom stuck in (badly) check if yours has it, the extra resistance could cause a higher reading maybe.
was driving at about 45-50mph was letting it decelerate on its own got to about 40 mph and on flicks the lights traction one and serv ligth and afterabout another 3 mins the engine management light flashes for about a min got it home scanned it and only one code this time a p0300
Random missfire will flag up if the CAT is struggling to cope with whats happening and the secondary O2 sensor sees that.
I get the light on if for example doing 90 for a while them back off and come of a slip road, the light will come on, mien says something like emission threshold exceeded or some other crap
ive had the solenoid off and wired 12v to it with vac and it clicks lovely ive not checked the wastegate actuator yet but car was driving fine before it was stood for 3 days il check the wastegate tmrw and think im going to get the injectors sent off for cleaning
right waste gate has resistance but moves freely by hand
removed the battery setup tray ect found a nice mouse nest removed the ecu no corrosion but sprayed them ect a cleaned it up abit put it all back together ideled fine with no dash lights for about 30 secs then up come the codes and you you can hear the change in engine noise
