tarmac terrorist
Here's some info from the Manual:
GENERAL INFORMATION
The accelerator pedal potentiometer is incorporated in
the accelerator pedal. Its replacement therefore
requires replacement of the accelerator pedal.
There are two types of pedal: with or without
kickdown point.
These cars equipped with cruise control/speed limiter
have an accelerator pedal with a point of resistance at
the end of their travel (kickdown).
This point of resistance makes it possible to quit the
speed limiter function if the driver has to speed up.
REMOVAL
Disconnect:
the battery,
the accelerator pedal connector.
Remove:
the three pedal mounting bolts,
the pedal.
REFITTING
Refitting is the reverse of removal.
CONNECTION
Track Description
1 Track 2 earth
2 Track 1 earth
3 Track 1 signal
4 Track 1 feed
5 Track 2 feed
6 Track 2 signal
Note:
A fault on the accelerator position potentiometer
causes changes in the idle speed or engine
operation (see Section 17B, Idle speed
correction).
17B-26
MOTORISED THROTTLE VALVE
The motorised throttle body carries out idle speed
regulation and engine air intake modulation functions.
It is composed of an electric motor and two throttle
position potentiometers.
When the engine is idling, the throttle position is
adjusted according to the idle speed setting. This
setting takes into account the major power consumers
(air conditioning) and operating conditions (air
temperature and coolant temperature).
When the driver moves the accelerator pedal, his
request is translated as a call for torque which causes
the throttle to open and the ignition to advance.
To eliminate misfires, facilitate gear changes and
perform the safety functions, the throttle valve
modulates the engine torque.
MOTORISED THROTTLE BODY DEFECT MODES
The motorised throttle body has three types of defect
mode.
Reduced Performance Mode: this mode covers
electrical faults for which there is a viable backup
solution for the injection system (loss of one of the
two tracks on the pedal or the throttle body).
This mode results in reduced acceleration and limits
the maximum opening of the throttle.
Driver Override Mode: this mode is also called
"Electrical Limp-Home". This mode is applied when
the accelerator pedal signal disappears completely,
but the injection computer still controls the intake of
air to the engine (automatic throttle control is still
operational).
In this mode, the injection computer imposes a set
engine speed for each gear ratio and imposes the
idle speed when the brake pedal is pressed.
Mechanical Limp-home Mode: this mode covers
breakdowns which result in loss of the automatic
throttle control (the throttle can no longer be
controlled).
In this case the throttle is in the mechanical rest
position and the injection computer limits the engine
speed by cutting off the injection.
GENERAL INFORMATION
kickdown point.
REMOVAL
Disconnect:
the battery,
Remove:
the pedal.
REFITTING
CONNECTION
Track Description
1 Track 2 earth
2 Track 1 earth
3 Track 1 signal
4 Track 1 feed
5 Track 2 feed
6 Track 2 signal
Note:
correction).
17B-26
mode.
operational).
controlled).
