Earths help!
CarlJ
Hi every1,
does any1 know where the earths are on a Megane F7R engine! I can only find 2. Battery earth and engine block at the back. I was told there is 1 on the gearbox but I can't find it.
Thanks.
Mine goes from the gearbox mount bracket (lower front ) to the inner passenger side chassis bit (can see it if you look through pass the wheel). And it's an earth strap if that helps. I'd take a pic but cars in the shop.
