Hi guys,
went today and got the clio on a dyno to give me a baseline to get the idea of what a std car will give, i don't think this has been done as yet, lots of pub talk about different cars , exhausts and the like, but no real data.
as you will see (pics please james) the car was running very rich above 4000 rpm, this i hope was due to the thermostat deciding to stick open on the run down to the dyno, this could cause the temp to be reported too low so fuel gets richened up to compensate, i took the trouble of recording the live data on a solus scanner whilst on the run this showed an eng temp of between 65-75 degrees c, this is too low and is almost certain to cause richness resulting in the jagged line on the graphs.
its my own car and in standard trim, well serviced with a pipercross panel filter, oil is mobil 1.
max hp as the graph shows is 207 bhp with 197 ft/lb of torque, this of course measured at the back wheels. you can do a run down test to compensate for flywheel hp but i find these are not a reliable test so don,t bother. as a guess i would say the losses in the gearbox are around 15% to 20% so you do the math. i did hear pub talk that there were hardly any losses but if you believe that why does the gearbox oil get hot?
the runs were done at TVR POWER COVENTRY, using a dynojet dyno. the reason for using tvr power was because their dyno uses winpep7 software and is the same software as on the bike dyno i have used at spr racing for many hours. this also is the same as janspeeds dyno where i am having some exhausts made, obviously now i can directly compare my data with theirs, possibly unclouding any issues in the future.
lastly i would like to thank TVR POWER COVENTRY for making me very welcome with tea, etc, and for their very clean workshops and easy profesional aproach with job well done, i would recommend them to any other member.
[album]4728[/album]
[album]4729[/album]
[album]4730[/album]
[album]4728[/album]
[album]4729[/album]
[album]4730[/album]
