5 GT Turbo Dannyb's campus sleeper project
So the lump went in at the weekend, drama free no issues so thats great!
However the list in my head of what needs to be done isnt getting any smaller! :help.gif:
and due to being shoved in the deep end of how these engines work (best way to learn lol)
I would imagine most of these questions would be aimed at @Adey
Is there some kind of wiring diagram? as i assume some sensors are not on the campus e.g. knock sensor
Carb piping routes? any kind of marked up picture?
pretty sure i can work out all the pipework for the turbo, oil feeds, water feeds etc
Anyways a couple photos
cant see the pics, might be best to upload direct to the site for viewing.
but with regards to wiring most is easy. knock sensor is standalone to the aei. On mine i had to wire in for the aei feed and fuel pump, i just used an ignition switched relay for that. Mine was mechanically pumped though so had no wiring at all. If yours already has an electrical pump you should have the aei and fuel pump wiring tehre already. But ask away as you go and ill answer best i can (y)
