Hi all my names dave and this is my clio thread. Im mainly on cliosport.net but thought this place is sutable for the clio.
Spec as of now is
Colour is United grey from a mk5 golf gti
Brakes are 197 brembos with hc brembo discs with brembo pads with braided lines and abs removed with dot 5 fluid
Suspension and steering
Vmax front coilovers eibech rear springs with cup dampers. Trophy wish bones and ball joints nd power steering removed
Transmission
Golf 5 speed gearbox fitted with short shift using
a sachs VR6 clucth/lightened flywheel
Ecu is a Mega squirt 2 3.2.1. ECU Mapped by Teamcarr.net Andrew Carr
Engine spec.
1.8 20vt Audi engine BAM
SCAT rods with arp bolts
Elring head gasket
Audi s3 semi forged pistons 20mm pins
Light weight vr6 fly wheel
Acl bottom end bearings
Crank shaft lightly polished for 100% trueness but using std size bearings
Metal water pump
Gates timing belt kit
Agu big port head and inlet manifold
Cable agu throttle body
TD05 18G Turbo from a Subaru Impreza
630cc Siemens injectors
Running a clio 172 coil pack
Solid engine rear mount and vibre tec mounts
Custom inter cooler kit
Custom intake
3 port boost solenoid.
Rolling Road at veuzu came back as she's running 300bhp 320tq so can't complain
Battery moved to the boot with a bmw e36 live wire
A few pics
Lots of ebays finest fake seude
Cheers for looking will update as and wheen
Spec as of now is
Transmission
Engine spec.
Elring head gasket
Metal water pump
Custom intake
A few pics
