v6 trophy 125":1pojlumm said:
SPIKE":1pojlumm said:
PUT YOUR NAME DOWN ON THE V6 DYNO DAY
hi have yuo built your engine ? when and where is the rolling road day ? i could do with knowing what 273 bhp @ wheels is at the flywheel ? [smilie=thanks.gif]
NO, not built the engine yet had a few problems, all the threads were pulled on the bottom of the block face, i think it was the crank imbalance that caused it as i cannot find anything else! am waiting to put inserts in all 8 threads but need the correct length, they are on the way from the USA as we speak.
as for main bolts, do you have a figure for the torque value on these, and are they stretch torqued?
as for dyno day it would be good if a trophy turned up as it should be the most powerful clio there. i got 207 at the wheels of a std car but it was frought with a couple of problems. overfuelling and a stuck thermostat, probably the same issue really.
see you at the dyno day.
