kariim
Hello Everyone.
I have a problem with my car and was hoping you could point me in the right direction.
i bought a 2012 laguna dci 1.5 with a blown engine.
i have replaced the engine and the car runs and drives fine, only issue i have is that there is a warning on the dash saying check vehicle and i have a couple of fault codes when using a OBD reader. the fault codes are; (translated from dutch)
also note i have replaced the current sensor and i have power on both wires on the current sensor. so im presuming the feed from the BDU is fine, no wire breaks.
DTC9211 UPC security and switching unit, supply feed
-open circuit or short with earth
intermittent
DTC922A Battery Dicsonnecting Unit
-Short with earth
intermittent
DTC9266 Battery Currentsensor
-Fault internally
intermittent
-recieved faulty seriesdata
intermittent
DTC922A Battery disconnecting Unit
-open circuit
PERMANENT.
the only fault that is permanent is the last one.
from the BDU, im reading 12 volts from all top 3 contact points.
again i have checked both wires on the sensor on the negative terminal. red was about 14v and the other (LIN i presume) was about 12 v.
do you have any information to point me in the right direction as im totally lost at the moment.
thanks in advance,
Karim
intermittent
-Short with earth
intermittent
-Fault internally
intermittent
intermittent
-open circuit
PERMANENT.
thanks in advance,
Karim
