Hi
Looking for part number and price of Breather pipe unit that attaches to inlet manifold and under and the paper gaskets that fit between both the inlet manifold and throttle body AND the paper gasket that sits under the inlet manifold
Im as technically minded as a goat but ive had a look through the manual and some posts on the forum and have found some bits and bobs, if someone who knows could just have a look and confirm or not i would more MORE than appreciative:
Manual
In the above manual, i believe the parts are:
Page 26 - item 22 (paper seals/gaskets for inlet manifold)
Page 27 - item 2 (Paper seal/gasket where inlet manifold meets throttle body)
Page 34 - item 1 (breather pipe) not sure the difference between A and B anyone?
According to this thread here, james has previously found them:
MANIFOLD GASKET RENAULT
JOINT CONDUIT ADM
Part number : 8200189379
£29.17 + vat (each)
As for the breather pipe, its is the item pictured on this thread
The last item is the same as the manifold gasket but fits between the throttel body and inlet manifold
i will try and make a positive comment on the breather pipe.
i have repaired these before as they are so fragile, the method of repair is to use adhesive lined heat shrink tubing, joining the broken bits together, this is the same as the yellow tag that the part number is on, the adhesive melts and seals the pipe whilst the heat shrink supports the repair.
this stuff is available from rs components, if its any help i can get this from them as i have an account.
