Megane Artic blue 225
It already has ate typ 200 in Dave thats the new version of super blue..not up to the job:read.gif:
Going to try the motul rbf 600 or even 660 see how that performs. Hopefully no more spongy pedal after a track session.
Give the meg a once over with Poorboys black hole then collinite wax to finish before Trax last sunday. It then promptly pissed down half of the day typically. A few pics of it cleaned up! Mot tomorrow.
20160924_151416.webp 20160924_153754.webp 20160924_153824.webp 20160924_160057.webp 20160924_160152.webp 20160924_160202.webp 20160925_110610.webp
Small update - Battery went flat due to lack of use - nearly had a crisis on our hands as the car is keyless and the passenger side door was tight against the garage wall - luckily it just had the power to unlock - charged battery and has been fine with a run out every couple of weeks. No other issues to report
Sits great on the cooksports though<3
A few parts in stock for next weekends gearbox swap to r26 with lsd. New outer cv for passenger side shaft as thread is damaged, new genuine renault concentric slave cylinder, oil & filter, brake fluid flush etc.20170517_231357.webp 20170516_220612.webp
20170520_163849.webp 20170520_163949.webp 20170520_160546.webpA few casualties along the way. Xenon level sensor pins snapped due to corrosion, drivers side inner cv pissing grease out of the splines, pipercross airfilter fell apart & lower dogbone mount shot20170520_163830.webp 20170521_184740.webp
New passenger side outer cv fitted - easy job one whack with the copper hammer knocked the old joint off, new joint knocked on in one hit20170521_152504.webp 20170521_124837.webp 20170521_124830.webp
Blanking plate fitted to turbo, lost a bit of skin doing that:D20170521_193448.webp
Its almost buttoned up again just passenger side shaft to fit & waiting for new airfilter etc. To be continued
