Leigh5t
Got a few more hours in on the inner sill/floor.
With the rot cut off the inner sill, there were two areas pf the floor lip that needed more attention.
I started with this front-most section
Template
Patch made
I'm still battling with the balance between lack of penetration and burning holes.
Now the other section
I then made up the front section of the inner sill. I've left a bit on the bottom and front to trim off once it's welded up.
Below you can start to see my plan. I replaced the rear section, I'm now replacing the front section, then I'll do the centre section. That way I've never fully removed the sill, so the position and integrity of everything is retained. Also, by doing it this way, I always have a reference to work with. This may or may not be the right thing to do but it made sense in my head!
Considering it's only ever an hour or so here and there, I'm fairly happy with the pace it's moving along at. Hopefully I'll get that front section finished this week.
Cheers guys.
Template
Patch made
Cheers guys.
