Tony Smith
As this is my third GTA project after my Safrane Biturbo engined black car and my 2.9i silver car, I think I'm going to call it Project G4P (Glutton for Punishment.) It's something I have considered for a few years and I had dismissed it to be honest. But then I got offered a cheap GTA Turbo which would have probably sat in my garage as a spares car. But a chance discussion with my very good friend Steve Dell who runs the RAOC changed my mind. He rents half his unit in Bicester to a small 2 man band classic car restorers who have been putting LS3s into Jensen Interceptors. They had been doing a bit of work on Alpines for club members and said they really liked the idea of putting one in a GTA. Turns out the all alloy Chevy lump is only a couple of inches longer than a PRV and if you add on the weight of the turbo is actually no heavy than the PRV.
Work is underway with the original engine and suspension already removed.
Car seems very solid with just one rear turret needing a small amount of welding, although they haven't got to the other area of worry to check for corrosion in the box section where the steering rack lives.
Most of the glass is ok which is a relief as is very hard and expensive to source now.
All suspension etc all removed front and rear
Most of the stripping is now done mechanically and any making good will be done over the next couple of weeks as the parts are assembled for the new V8 subframe.
So plan is to build up a new rear transaxle with new and spare parts I have, that bolts straight in as per original so that the car can be swapped back to original if required. Spare subframe back from shot blasters.
These are getting bought next week.
LS3 is Corvette spec 430bhp and the other pic is all the stuff to run it.
