Tested all sensors and the wires running down the centre channel to the back, all seemed ok. rear sensors were a little lower than expected, in the region of 0.9 but as both were the same didnt seem too suspect.
Took it for a drive :angel: and didnt cure the problem either...
Will probably jack it back up and get dad to put it on the scope and check for a pulse when a wheel is spun.
Any other ideas..
out of interest, in the haynes it shows the ABS wiring to have 2 bulbs attached, one runs off of the computer under passenger chair, but when that is unplugged the light on the dash is still on... Where is the other bulb connected to?
Just to update that the ABS problem is now sorted.
Popped over to see Interior Phil over in Slough yesterday, took my ABS computer with me which we popped into his car and gave the same ABS light on problem I was having.
Luckily he was able to dig out a spare which i tried and worked fantastically. Dave your a legend, and many thanks to Phil!
