abs to non abs converstion question
ant84
as reevios posted b4 for me im going form abs to non abs, one or two questions......
do i need to change my hubs and drivershafts?
all how much am i looking to pay for a non abs master cylinder and pipes and so on?
cheers for you help peeps :mrgreen:
no and as I already said you have the right master and servo. you just need to rmeove the pump and change the brake lines
sir you are wicked thank you.
next thing were can i get brake lines from and what calipers can i up grade to for better braking (im on a budget)
buy a roll of 25 foot brake line from a factors, buy unions and then flare them.
You can go to 280mm brakes with bits from clioII/megane. Clio 2 will be easier but you need the hubs, struts etc
