ABS removal...
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    abs
G
Guest
Decided to remove the ABS on my car, I've changed the master cylinder to a non-ABS one, re-done all of the lines, removed the ABS unit, rings etc etc... however one thing I haven't changed is the bias valve/unit box on the rear, does anybody know if they are the same on ABS and non-ABS cars?
Thanks
Craig
did you manage to remove the sensors from the hub in one piece? I'm after a set... :D
Not yet, I took the complete hub off and have left them on there.
Didn't want to remove them just yet as I've heard they break very easily!
Craig
MAXIBOY":1uvvara3 said:
they have a different part number i think
Any idea on the differences?
I can't picture how it would affect it on the rear.... looking at your project pictures, everything seems the same.
Oh well, only one way to find out.... fit it and try it! :twisted:
Craig
might be different as theres a higher pressure due to abs. just might need adjusting
