21 Turbo ABS pump flexi hose.
Red21
Got a slight issue with the ABS pump flexi, it's split which isn't surprising after 28 years, and it is NLA from Renault.
Everything is OK though as I have managed to find a couple of places who have made up some samples to check fitment and just waiting for the correct length Banjo bolt so I can check things.
Once things are finalised I may order a few sets.
WP_20161203_14_16_51_Pro.webp WP_20161203_14_17_05_Pro.webp WP_20161203_14_17_23_Pro.webp WP_20161203_14_30_05_Pro.webp
What are you paying for em Rich? We could probably make these up in the same way as the clutch lines if it's quite a lot of £ (but not worth messing if its under £40ish)
