hooverphonique
abs light comes on after disc change
Today i changed the rear discs on the 19 16V. They came from the factors with abs-rings and bearings.. I briefly wiped the abs sensors when the discs was off.. ABS light turns on as it should when turning on ignition and then goes out.. After driving a short distance, it comes on again.. Is there a way to tell from this if I broke a sensor/wire/triggered a bad connection or if it's the new rings that don't work?
Bosch abs btw..
Bosch abs btw..
