Hi all,
here i am with another issue that has been bugging me for a few weeks and i'm still not 100% sure what's about.
When i start the engine, cold, it runs at first try and very smooth. I can drive it either normally or flat out that everything works as it should.
However, if i stop the engine not enough time to cool down again like first in the morning, it runs at first try but a bit shaky. When i accelerate at first it hesitates but after 2.000 rpm looks normal. If i let it come down to idle, idling is not flat anymore. It varies 100 or 200 rpm up and down. Driving it in traffic is a nightmare because it judders all the time, but if i go flat out it looks normal again
This only happens when the engine is still warm from the previous run.
I've began with the obvious, cleaning inlet manifold, idle valve and still the same. Then i went a bit further and replaced spark plugs with Bosch H3CS, new plug cords from BERU (previous ones were Champion with 6 years old), new rotor, distributor cap and body (that connects to the camshaft). Still same behavior.
Then a bit further again i replaced the water temperature sensor and MAP sensor. Still the same.
I've put WD40 in every plug i could find for every sensor and nothing changed.
Fuel pump is also 5 or 6 years old.
Accelerator potentiometer is practically brand new.
I think i've narrowed it to either one of these that can be malfunctioning:
- fuel injectors (they are 25 years old, maybe they need refurbishing)
- ignition coil or controller (this one i would be surprised because i've replaced the entire thing (coil and controller) 6 years ago. The previous one was there for 19 years
- fuel pressure limiter (this i'm not so sure, but who knows
Anyone have any idea of what could be causing the problem?
Can diagnostic computers like XR25 ou Can Clip check each injector, check for ignition coil issues, variation in fuel pressure?
Thank you in advance for any help
