Wanted 21 Turbo exhaust + caliper spring.
jack11electronic
Hello,
This may be a long shot, but i'm after a full exhaust system to replace the 3" one on there that's far too loud on long journeys. Does any one have a more modest (quieter) twin tailpipe system? was looking at these Ligne Inox Renault R21 2L turbo (Origine ou 63mm) Equipement Auto Seine-et-Marne - leboncoin.fr , Ligne ?chappement inox GrA Renault R21 2L Turbo anyone tried these?... If not then if someone has a standard downpipe I could buy ? then I can pop a o.e system on .
Also after a spring for the rear Bendix caliper, as the carrier is rattling around like marbles in a washingmachine! not having much luck fiding new ones.
Really appreciate any help.
Jack
Most 3" systems are built using cosworth system, which have various boxes, some with minimal baffles.
I tried to source an oe or stainless version for James's with no luck. Personally, and I'll be doing the same with mine, is to just add a bigger baffled back box with tailpipe you want.
No idea on the mentioned system.
Caliper springs seem to be just as difficult. I had a similar problem but there was some wear between the 2 caliper sections so I had to shim the angled bit that keeps the pads in.
Thanks for that Haz! Really appreciate the advice.(Repeating myself) but do you happen to have a spare o.e down pipe ,that you would be willing to sell? as iv'e got a o.e center + rear that I could pop on. Other wise i'll look into ordering the above system when i'm next in France.
Jack.
These springs are MUCH better for the rear pads than the OE 21 ones, they sit under the pad on each side (you need four per car). I only have this one spare for mine, in case one of the four on there breaks.
That's what ended up using from a box of bits, I didn't realise they aren't off a 21.
I think I've on oe downpipe but the flange has been butchered and a peice if stainless fitted to mate a stainless version. I'll dig it out for a pic if any use?
Hi Mate, if it's not too butchered to take a o.e centre section ,then I'm definitely interested=D
Jack.
