Does the accumulator pump work? When you start the car up first thing, or if you pump the pedal a bit with the ign on, you should hear it kick in to life and buzz away. Its the thing under the expansion tank with the black ball on top (the black ball is where pressure is stored).My abs stopped working and brake pedal is harder than it used to be.
I assumed the problem was in the accumulator thing and i've replaced it. Also i replaced one wheel sensor that was malfunctioning.
Still doesn't work, but warning light is off now. Sometimes when i go over bumps on the road the yellow light flashes for a bit.
Anyone has had this problem?
Then the new accumulator isnt working then surely. It shouldn't feel superhard and bouncy on the pedal.I will run some checks with a multimeter and clean the sensors and rings. But yes the pedal feeling didn't change much with the new accumulator cylinder.
The ABS unit you have in UK versions seems to be a improved generation of the system. Does it have a regular brake servo?
Yes, but if your pedal is bouncy hard something must still be wrong... unless the pedal is fine and its just that you dont have anything to compare it to?But if i hear the pump working and no lights come on when i brake, and if i depress the brake several times the pump works again, doesn't that mean the accumulator is working?
Sorry Dave but you agreed with him when he said 'the UK car doesn't appear to have an accumulator sphere'
You OK? Lol
If you want one posted to you, I'm sure we can sort something out among us.
Yes, sorry I phrased my reply badly. All UK Turbo's have the accumulator but the setup is very different.So you're saying that there are some models in UK with the black accumulator cylinder?
