You're lucky I'm only from Peterborough @TNT Andy so I can understand your Norfolk'n'chance accent.. :bv:Ooooaaaarrrrrr
LOL - Steve - I'm From Rochdale, and never, ever been accused of being a carrot cruncher from Norfak matey. Get yer ears checked.You're lucky I'm only from Peterborough @TNT Andy so I can understand your Norfolk'n'chance accent.. :bv:
Do a cylinder leakage test first Dave before taking engine out.
I disagree with everyone because I'm busy running up the road with a straw in my mouth..![]()
I disagree to agreeI agree to disagree
I don't think back pressure in the exhaust would cause it to die. It'd choke and stall because it can't get rid of exhaust gas but not kill the lump.
I've never heard of a banana in the exhaust destroying an engine either!
Did CTM build the engine? I've seen a lot of their work on GTT engines and my 21T and its normally very goodCTM wanted it back mate.
LOL ,like it Steve..... how far did you get ?
Taking the engine to CTM tomorrow to be stripped and inspected.
We will find the results of blocking up your exhausts soon.
Took the manifolds off and number 1 ex is very oily..........rings ?
I agree to disagree
Hi Dave - FYI = The only time I blew a set of rings was when I pushed a relatively small turbo way past it's efficiency range and the charge temps must have been off the chart on a relatively small intercooler.
ye, but its depends on which one you haveAs an aside does the adaptronic data log?
Good point Andy, pushing turbos past their efficiency certainly causes heat problems.
Good to hear Clarkey, hopefully it's alright.
Question from a noob, why do run longer pushrods ?
I assume Clarkey is running a recut cam. When a cam is cut from an OE one material is removed from the back of the lobes, so the tappet can be adjusted further down and therefore the original lobe tip extends further relative to the adjusted tappet position giving more lift. This sucks up the adjustment of the tappet so with a longer pushrod it compensates.Good to hear Clarkey, hopefully it's alright.
Get some custom push rods made up, Glen Robson is the man to see about this. He was forever bending them on his old c1j when hitting the hard cut limiter.
I have a billet cam - adjusters are still pretty much maxed out.
