I like the cut of your jibFit a turbo and re-map it......
Hello Adey , According to one of the so called experts the 5 auto engine like you used is supposed to have a slightly hotter / better cam profile to a manual engine car .Potentially, though I've done this to add reliability primarily. After having a coil die on me, the "wrong" dizzy fitted as it was the one off my 1108cc and then the potential fuel pump failure I decided to replace it all with more modern items. Watch it all fail dramatically
With the ecu in place I should be able to set the optimum ignition timing at every point in the rev range and being "3D" and having a map sensor equally for all load points too. I should gain power and driveability in most places but peak numbers will likely be close or unchanged from what it already has. So to answer that question.... yes and no lol.
I think the manifold was a one off from @BobG, not sure if he made it himself or was purchased elsewhere?
I was very tempted to slap a cam in too, maybe in the future with a head skim to bump compression slightly. Its never ending isn't it.....
I also heard this rumour back in the day.Hello Adey , According to one of the so called experts the 5 auto engine like you used is supposed to have a slightly hotter / better cam profile to a manual engine car .
| put a electric fan on mine when i first built it pushing through from the back panel and worked ok but not in the hotter weather so put the pully driven fan back on and never had a issue . The electric occasionally cuts in when moving in slow traffic but not for long and i dont have any undertrays .Indeed, it's been pretty cold and wet here. My makeshift gazebo worked wonders though
View attachment 222537View attachment 222538
With regards to the fan m, I had it pushing air through to the engine, same as the oem one. My concerns came from not having an under tray on one side due to the tubular manifold and then me thinking the air would be stalling in the bay because of it. Where as the fixed fan probably over comes that?
I've had that fault twice with Lumenition, once on liz's car and once on the Dauph. Too much coil on time, heats up and starts missing. Reassuring to know you can get the same result by having the points shut....So this has not gone to plan.... Few things to go through.
I had an mis sync issue that seemingly got worse the longer the car ran. Seemed to run perfectly when stone cold. I've been pretty particular with the routing of wiring to minimise interference to the ECU. Anyway, replaced the crank sensor to see if that was the issue. No change. Started diving a little deeper, decided to remove the rad fan that was in the same vicinity (that and I was giving myself a headache about temperatures and direction of airflow, @Steve Swan I should have just listened to you in the first place, mechanical fan back on) still no change. Remade the earthing points and added extra to make sure all was grounded nicely. Still no change...
Had been calling my mapper whilst trying to get it diagnosed and correct before I take it to him. Didn't want to waste his time or my money so he was throwing some ideas about.
Started looking deeper using the software for the ecu, noticed that it was seeing a signal of some sort constantly. There are filter settings to cut these out and aren't usually a problem unless they are strong enough for the ecu to think its seen a trigger tooth, (think of it like background noise). There's software based things you can change but switching the filters on and off didn't make a difference to the signal or running.
Anyway, kept digging until the car ran on 2 cylinders. That's weird... followed by a hiss and a bang. Took a look around everything and found the coil pack to have exploded!!!!! My first thoughts were that it was a dodgy coil pack.
Made a call back to the mapper and he throws some more ideas around. Generally coil packs over heat if they are been driven too hard or for too long or a mix of both. Asks me to triple check the loom which I have, and found no faults that I can see. Noted that there was continuity with the ecu powered back through one of the coil trigger wires.... This would suggest that the driver is stuck on for one half of the coil pack.
Anyway pull the ecu and do the same on the bench, sure enough the ecu is showing continuity to ground through one of the coil drivers.
Seemingly I have a dead brand new ECU. The issue with the misfire creeping in as the coil heated up.
Anyway a ticket has been raised with the supplier, we will see what they say/can do when business opens as of Monday.
Hi Adey,Indeed, it's been pretty cold and wet here. My makeshift gazebo worked wonders though
Alright Mark. Calm down.Seemingly I have a dead brand new ECU.
