Water pipe needed
jrmrossi
Hi has any one got a water pipe thats near the gearbox i have not seen the pipe but have its part number 6020010902 it says its a hose return, i will have a look @ it when i get a bit of time and update which one it is [smilie=thanks.gif]
James":2zdj6es9 said:
Last time I looked up any hoses for the Vees none of them were available in the UK. :(
if you have a pattern i think samco will copy any hose in silicon, if not samco try the web under custom silicon hoses.
Can you just buy a generic flexible hose for now, if there is T-piece in the OEM hose (can't remember) make a hose up with a metal T-piece if you're stuck ...
6020010902 WATER HOSE RENAULT
Available to order from Renault £62.27
Item 3
