hooverphonique
I've discovered that there's water coming out behind the trim that covers the nuts for the rear hatch.. removing said trim reveals quite some rust, unfortunately, but that's no wonder if there's moisture trapped in there
It's not coming in through the hatch gutter since there's no holes or rust there, and I don't think it's from the sunroof either, as it seems dry.. Now I wonder if it's common that water is coming in between the rear washer and the roof or maybe the washer itself is leaking washing fluid?
How is the washer removed? Do I just pull it up?
