under tray bolts
  • Start date Start date
A
Anonymous
Think i am need of a couple of undertray bolts
anyone know the measurements etc of these and a place to buy other than renault
should eb easy enough to fit i guess one on some ramps or axel stands
cheers
Get some stainless steal 6mm bolts and penny washers about 25mm long also put some copper grease on the threeds b4 putting them in. Trust me you will be glad you did when you need to get them out.
Well in that case mines different because mine has captive 6mm riv nuts and 6mm bolt clips. Not a self tap in sight
Is yours a Mk 1 or 2?
If it happens again I have a riv nut gun I can lend you welding damages the galvanising on the subframe.
Its a mk1
so what is that i need then?
where tho two trays interlock are where they are not held in. seem to be hanging a cm down. would just be nice to get it sorted.
where would I buy these nuts/self tappers? halfrauds? i get freindly discounts in my local lol
Try this guy
Mark
CLB Fastners
01933 272592
If he does not have what you need or cant get it then theres no hope for any of us.
Tell him Simon from Chroma Visual passed his number.
