Clio Tutuur's Clio R27 turbo
Last weekends progress:
New, genuine, rear discs drilled to accomodate for 5x112 again aswell as fresh pair of front hubs
i1230.photobucket.com_albums_ee490_tutuur_Clio_20R27_129D975E_aedd8dea2cdd7c0d977e2e49a281eaf5.webp
Oil feed and water feeds sorted, now just have to do the oil return and fab a bracket for the wastegate actuator
i1230.photobucket.com_albums_ee490_tutuur_Clio_20R27_030E4105_3b227dbb270af46f58705c1908f36929.webp
Calipers stripped, cleaned and treated with some Gtechniq aswell
i1230.photobucket.com_albums_ee490_tutuur_Clio_20R27_046FBE77_3a1037a5ad536fa58339b90a0d51125d.webp
Alloy v-band made as heatsink for welding the v-band couplings
i1230.photobucket.com_albums_ee490_tutuur_Clio_20R27_D6B8F622_e7ddd4dcbc6ab6f8984e2b9af4c794af.webp
I would never proclaim I am an expert on cars , but I am pretty sure if they are in your boot , you are doing it wrong
hahahahah! Luckily the one they where in also has four wheels mounted. They are now patiently waiting in the attic of my garage
A bit of progress again, my friend who was going to weld my v-bands didn't have any spare time so i decided to do it myself. With a few hints his side and using the alloy heatsink they turned out pretty well.
i1230.photobucket.com_albums_ee490_tutuur_Clio_20R27_E98BCC70_0bbf46e036e940f9f77fdfd520eed882.webp
Exhaust is nearly finished now, just have to make two lambda bungs in the downpipe and redo the rear section mounts as i want to make them adjustable so i can level both tailpipes perfectly.
You confident you have the penetration you need?
( no laughing at the back )
yet some more progress, pressure side of compressor housing custom made to suit standard boost pipes:
i1230.photobucket.com_albums_ee490_tutuur_Clio_20R27_031EFD86_fcb181f2db9b541ebef6068a10014e9a.webp
took a while to get everything lined up as the silicone hose only just fits between the coils!
i1230.photobucket.com_albums_ee490_tutuur_Clio_20R27_8EBCACA8_bce4cc7fecbaafa5ed5ee34dc57b058d.webp
lambda bungs added to downpipe aswell:
i1230.photobucket.com_albums_ee490_tutuur_Clio_20R27_739F37FE_fe472216dae64a5fbc97cdb8f45dc8ad.webp
