i'm not going to just chuck it together but I do know what you are saying.
if I take the measuresments and everythings fine, which it will be given the state of the crank and journels, make sure everything is clean it'll hopefully be fine. I've checked them seperate as did the engineer, not done them closed.
The only thing the plastiguage seems to do to me is give you another device to confirm the maths or some balls up, and surely the maths itself is fine if you measure it correctly and don't fuck it up
So, balls to plastiguage?
Even with that, plastiguage doesn't stop you getting a bit spec of grit in there anyway? I mean to say, it could happen eitherwhich way. Just got to be clean, take time and check rotation as I go.
It's been cleaned before it got wrapped, but it'll all get cleaned again. As long as the bearings are seated right it's a doddle and the journels are good nick. I'll just take my time and spin it after each piston etc.
tried to get a stand, snow delayed them at machine mart apparently. don't know when they'll be in.
i'll maybe grab you across at the weekend, not sure whats happening with the work got time booked off but no one to really replace me so watch this space
