solinakias5gtt
after puting a mocal oil cooler i have problem with oil temp now.inside traffic after long hour i see 75 c maximum and if i take the high way to long corse the temp falls to 55c and more.i took out my oil plate adaptor and check the thermostat inside with hot and cold water it seems to be moving.to be honest i was expecting some better system to allow or not allow the oil to go to the cooler but it seems that the mocal runs all the time the oil and if gets more than 85 c it just the thermostat moves and just give more flow to the oil to travel to the cooler.
the oil pipes tha the mocal kit had inside is allmost double the diameter of the std oil pipes of the 5gt.i was thinking maybe from there i have more flow and speed my oil that i should have and maybe if i fix two new oil pipes with the std diameters i cut the flow of the oil and gain some temp.
what u say gyus ?
what u say gyus ?
